It is currently Sun Aug 17, 2025 3:41 pm
PostPosted: Sun Aug 10, 2014 12:30 pm
First name: EddieLee
Last Name: Brown
I am planning to put a graphite rod on either side of my truss rod. Can you share any tips or pictures?
_____________
EddieLee
These users thanked the author EddieLee for the post: timoM (Mon Aug 11, 2014 1:28 am)
PostPosted: Sun Aug 10, 2014 1:22 pm
First name: Tom
Last Name: West
State: Nova Scotia
EddieLee: Just a couple of thoughts. CF rods can serve more then one purpose. They can stiffen a neck and they can help prevent any tendency for the neck to twist. To add to stiffness plant the rods as deep as possible and use as deep a rod as possible. To help prevent twist, space the rods as far apart as possible.
Tom
PostPosted: Sun Aug 10, 2014 2:42 pm
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
A couple of years ago, I built an all western red cedar guitar with two square CF rods in the neck. On each side of the truss rod.
The CF rods ran the full length of the neck including the finger board extension support. Glued in with epoxy glue.
I used a router table to cut the CF rod slots and the truss rod slot when the neck blank was still square with no peg head ears.
PostPosted: Mon Aug 11, 2014 12:06 am
First name: Jeff
Last Name: Dillard
This went on my first acoustic.
PostPosted: Mon Aug 11, 2014 1:29 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I got a 2 CF rods from LMI. They bend like a piece of maple. So how does a CF rod add stability?
Jason Moe
LaCrosse WI 54601
PostPosted: Mon Aug 11, 2014 3:32 am
In all directions?
PostPosted: Mon Aug 11, 2014 11:43 am
First name: Danny
Last Name: Vincent
I use this CF http://dragonplate.com/ecart/product.asp?pID=696&cID=20 and I use this trimmer http://www.busybeetools.com/products/LA ... AKITA.html with the fence set up to cut the channels. Use a 1/8" spiral cutter and you can have the channels cut and the CF glued in in about 15 minutes. I have thick, straight Maple caul to hold the neck flat during glue up. It is one of the few places that I will use 5 min epoxy.
PostPosted: Mon Aug 11, 2014 4:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It shouldn't. Cut a piece of maple the same size as your CF rods. Clamp both to a table, same amount extending out. Attach a thread with a hook to each, and start adding washers to each. The CF should not deflect nearly as much (in BOTH dimensions). Do the test in both dimensions. I'm gonna guess that in the tall dimension, both will tend to "roll" to left or right after a certain amount of weight (depending on length of cantelever). Thats the dimension you are interested in anyways. Which one rolls first?
PostPosted: Mon Aug 11, 2014 4:48 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I really like this idea. Curious if the added weight is noticeable. Also, does this make it "harder" to turn the truss nut? If I made my neck out of steel, say, but still had a wood finger board, since the neck is now super stiff, wouldn't adjusting the truss rod only act to deform the finger board? Since neck is really wood, but stiffened with CF, will I get any deformation in the FB?
Sorry for the overly technical question...
Edit: Never mind... I see where they are (in this application) to help prevent twist (meaning you want them out from center as mentioned above)
anybody use these folks? http://dragonplate.com/ecart/categories.asp?cID=20&p=2
